Will do, and not a problem.
8 days and no response.
Glad I didn't hold my breath.
Does anybody know if the height inputs on the height sensor are normally closed or open? If normally open I would think you could just cut both the high and low input wires. If normally closed than I would think you could ground both input wires at the sensor. If they are variable then maybe a resistor could be soldered in series of both inputs.
The height sensor is connected to the frame crossmember at one end and at the left rear upper control arm at the other end. The sensor gets shorter when the rear of the vehicle goes down and longer when the rear of the vehicle goes up. Magnets mounted in the lower slide portion of the sensor move relative to the sensor housing, generating a signal that is sent to the control module through two small Hall effect switches that are attached to the sensor housing.
Movement of the magnets determines switch opening and closing. At trim height, the switches remain closed and the module receives a trim signal. Upward movement of the magnets will open one switch to indicate a high condition. Downward movement of the magnets will open the other switch to indicate a low condition.
I thought you had it fixed![]()
[/LIST]The sensor switches have a possibility of 3 states:
I know what I would do to extinguish the Check RAS lamp. I'll let you decide your route.
- High line closed, low line open. (Suspension too low)
- High line open, low line closed (Suspension too high)
- High and low lines closed. (Suspension at trim)
Good luck.
Looks to me that the high and low lines should be grounded.
It did not work.I left everything connected and used scotch locks to tie the Black/Pink, Orange/Black, and Pink/Black wires together.
The sensor will not work without a voltage applied to it (~3.3V) !
Voltage is required to make the hall effect devices work !
noOc does that mean it only should pump at the 60 minute mark?
I had an 86 Mark VII and it would reset and squat the car after you shut the key off and shut the door, I take it the town car does it differently?
I had a neighbor that told me the same thing about my compressor going off. If it only does it once or only for the first 60 minutes I am ok with that. I travel a lot and just didn't want the battery to go dead if it sat there so I have been shutting the switch off in the trunk to make sure.
