It seems like you have have broken the RF coil for the PATS, or you didn't get everything reconnected correctly. You did disconnect the battery before unplugging/removing the cluster, right?I removed cluster to put in leds i put back in and it would noy crank nor start
How can i bypass or reset it with out key fob?
After it stops blinking rapidly it just flashes twice with a second between each flash..idk what that means..before unplugging the wires from cluster i did have negative disconnected.but i had it connected when i started unscrewing the screws for cluster and 1 slip down and tapped the ignition coil and made a little spark.It seems like you have have broken the RF coil for the PATS, or you didn't get everything reconnected correctly. You did disconnect the battery before unplugging/removing the cluster, right?
The PATS light is flashing rapidly when you try to start, correct? Wait for it to slow down, and it will flash out a two digit code. What is that code?
The "key fob" is the remote for the doors. It has nothing to do at all with the PATS.
To marry PATS to another key if you only have one key, then you need at least two of the correct PATS keys, and you have to get them cut for your car. Then, you can use Forscan to marry the car to them.
Yes i apologize ignition cyclinder is wat i meant to put...so try replacing PATS transceiver and ignition coil?That's PATS code 11. It means the PATS transceiver is not working. When you say "ignition coil," you must not mean any of the actual ignition coils, because they are all on top of the engine. Do you actually mean the PATS transceiver coil that encircles the ignition key slot? I assume so, as this fits with the problem. It sounds like you either blew the coil itself, or more likely the PATS transceiver. I'd replace both as a set.
I mean ignition cylinderYes i apologize ignition cyclinder is wat i meant to put...so try replacing PATS transceiver and ignition coil?
Ok ill start there thanks for the helpNo, there's no reason to believe anything is wrong with your ignition cylinder. It's just a mechanical key lock. I referred to the PATS transceiver and the PATS transceiver RF (antenna) coil.
After replacing PATS TRANSCEIVER do u have to reprogram anything?No, there's no reason to believe anything is wrong with your ignition cylinder. It's just a mechanical key lock. I referred to the PATS transceiver and the PATS transceiver RF (antenna) coil.
I believe that you do. What code is the PATS light flashing out now?After replacing PATS TRANSCEIVER do u have to reprogram anything?
I have the forscan and it put out p1260 andB1681I believe that you do. What code is the PATS light flashing out now?
Thanks im glad i didnt get to expensive.i dam sure didnt think it even had a fuse that was the first place i tried to look .didnt know it was a third fuse box on passanger side smhWas going to be my suggestion I changed some bulbs out and blew the fuse as well on my 1st ls took me a few hours to figure it out. Glad you found it.
