Blincoln2005
I have a 2005 Lincoln ls ,none of my front lights work , I checked fuses but nothing works has anyone had this problem before
Try checking the switch... make sure it's still functioning. After that, wiring is your only option. Doesn't seem likely though. You could also test the fuse connector with a multi-meter and see if any volts are coming through, check the light connectors and see if volts are registering.... I'm thinking the problem could be between the switch and the fuse box but I am not sure....I have a 2005 Lincoln ls ,none of my front lights work , I checked fuses but nothing works has anyone had this problem before
I checked the voltage on the headlight plug with a multimeter it says 12.2 volts and I replaced my headlight switch a couple months ago
oil is good I just changed it
Is that pic with engine running
... or key on, engine off?
So, what is your answer to post #4?This appears to be an old thread.. but I have a 2004 Ls V6 and I'm having this same issue. Does anyone have the solution? Was really hoping to find it on this thread.
In that case, your problem is most likely your FEM.All the tail lights work including hazards and turns.
I have no lights working in headlamps at all. no bakclights for instrument cluster and my pedal levels no longer work. Checked every fuse in all 3 panels. Fuses are all good. All my other dash lights work as well as dome light.
And I have also noticed the oil light. Even tho the oil is good and oil level is where it should be.
Considering the age of the LS, how non-Lincoln it really is, and how few of them there ever were. Most Lincoln dealers are probably a bad bet. Maybe look for a local independent that does a lot of Jaguar work....
Really hope it's not the FEM. They seem to be hard to come by these days. Atleast plug and play. I might have to drop this thing at a Linclon dealer and let them deal with it.
