kgtorino
Hello Everyone, I've done a search, but can't find an exact problem like mine...(unless I missed it ) . 2006 LS, 3.9. Approx 105,000 miles. Car does not start after a run. It seems to be the longer the run, the longer it takes to cool down to be able to start again. ( I say cool down, but not sure if that's accurate or not). A 5 - 10 minute run will require a cool-down of about 5 minutes, whereas a 2 hour run, the car won't restart for up to 30 minutes. The car never stalls, and starts cold fine. (also engine runs good cold or hot ). Just can't turn it off if I run into the store. I've changed fuel pump relay ( thinking it was getting hot, with no luck ) . By the way, the car does not overheat, or lose coolant. I've changed the Degas bottle (with an OEM unit ) due to a leak, and I properly bled the system. I did have an EGR code about a month ago, (code P0406)
but I cleared the code, and the light hasn't come on since. This hot start issue has been going on long before that. It will crank, just doesn't fire up. Once it "cools down", it fires right up. Anyway, if someone could point me in the right direction as to what to try next it would be greatly appreciated !
Kevin
Kevin
