Danson
Hey everyone, my 97's obd port is not working the fuse is fine when you plug something into it nothing gets power is there something else i should be checking?? thank you help is appreciated!
your scanner should work without ignition power, it is probably a loose pin or ground problem-try wiggling the harness or use a flashlight to see if there is corrosion in the sockets- does your cigarette lighter work or does the socket have power?-for some reason i think they might be related...only other possibility if not a fuse or harness/wiring is ecu, that'd be pretty unusual.
