Kinda. I tried splicing RCAs but could never get my Z110BT (now Z120BT and hopefully soon Z130BT) working right with the stock 4-channel amp. I would get random engine / ground noise. However, the stock subs + sub amp works beautifully - just need to put a 5V regulator circuit inline to prevent the loud thump on powering up the HU.What if I want to keep the stock amps and just replace the HU? Will that work?
I don't believe so :The door speakers arent infinity from factory are they?
Yea those r nice. If you have infinity speakers anyways. Lol.
The door speakers aren't infinity from factory are they?
damn the splash screens alone make me want to upgrade my stock nav headunit...
i figured going this route would be much much easier. this place has some of the best write ups on things things that have been done, they just need to be dug upI got it to work going through the stock amp and subwoofer (significant savings and it sounds pretty darn good).
this sould be a simple fix, if you wired the factory amp inputs up to the appRadio speaker wires, then yes. all you need to do is switch them over to the RCA outputs. forgive me but i cant remember, but their might not be a full set of preouts for the appRadio, i do remember having a discussion about the limited ability for upgrades later when we installed the last one. if it doesnt, you could either use RCA splitters, or a damn good LOC.I do think I have double amplification going on but I think I can fix that easily. System is as loud as I need it on volume setting 3 to 5.
no problem, glad you got it hooked up when the "Pro's" couldn't figure it out!Thanks again for all of the input guys.
Not noticeable enough. I am sure it was a difference but it was ever so slight.
I am not sure what the stock amps wattage output was, but i am thinking it was surely morethan the head unit. So it may take a little more notches to get it louder on the volume knob.
I have a copy of a late 2002 press-release about the THX system and it states:
The 2003 Lincoln LS THX-certified system offers:
• 10 speakers, including four high-sensitivity two-way speakers (one in each door) and two subwoofer speakers in the rear package tray;
• Four 50-watt amplifiers to power the door speakers and two 32-watt subwoofer amplifiers for high output without audible distortion or compression;
• THX customized equalization to deliver the best possible sound to each seating position, and three user-selectable modes that optimize the sound for any number of passengers;
• 107-dB maximum sound output, combined with undistorted output peaks in excess of 120 dB, to preserve the music’s dynamic range under all conditions
Good info! Shoot i think im just gonna bypass the amps then. HU's push 50w anyways. ...
