Official blown Mark VIII thread!
LaserSVT
Waco
Alright boys and girls I thought it was about time we had all our blown brethren in one spot. So lets do a roll call! Tell us who ya are, what year Mark, blower, engine mods, boost, HP and future mods set in motion. Also an engine shot and exterior shot. :)
Please guys keep the banter to a minimum. This is to help get all the blown Marks in one spot so when people do a search then they can see all the different ways in one place on what can be done. :)
Here, I will start us off:
Bill, my second Mark VIII. I live in Dawson Texas and am always willing to help a fellow enthusiast. Car is a 1998 Pearl White LSC.
Blower: Custom Kenne Bell 2.2L with bypass valve
Intercooler: None
Boost: 16.2psi
Power: 384/398
Timing: 8*
Intake air temp: ? Way too much!
Heads: Stock
Block: Stock
Exhaust: Stock manifolds/cats, Magnaflow res-x-pipe, 2.5" mandrel exhaust, Borla Pro XS mufflers
Fuel system: 255LPH pump, 42lb injectors
Tune: SCT
Gears: 3.73
Diff: Cobra TL with 4 clutches
Trans: Stock
Future mods this week:
Lower boost
Relocate IAT sensor
New coils
Goal: 400 rwhp at 11-12psi and lower IATs
Soon mods:
Meth injection
YouTube- Mark VIII Final Dyno run at Gearheads
i want to post in here but i cant quite yet lol!
ahhhhhhh screw it, i went and put it on tonight lmfao!
My car is a 1994 Lincoln Mark VIII, It's supercharged. I would post pics and a mod list, but I'm in the middle of changing/adding a few things.
If anyone searches my post you will find details on my Kenne Bell build and my Vortech build.
Was trying to condense all the blown ones in one place to help future searches so there isnt "Can this one fit? How about this one?" kinda stuff. Since we have a wide variety of different blown Marks it would be a nice place to start I thought.
Vortech 7 PSI supercharger. 90 mm MFS. 255 GPH fuel pump. Screamin Demon coils with Live wires. Kooks headers into 2 1/2 inch dual exhaust through a Magnaflow X-pipe resonator. 3800 stall with lock up. 1997 Mark transmission with Dirty Dog valve body. Transmission cooler and Mercon V. 4:10 gears with traction lock. 17 by 9 inch Lincolnmotorsport Cobra style wheels with 255-50-17 BFG comp in the rear and 245-50-17 in the front. Future Drag radials, A/C, Battery to trunk, Weight reduction. Very detailed clean up.
Jeb, still working on my first mark since 04
Blower-custom kenne bell 2.2, 8psi
B-heads-non intercooled, forged internals
built updated tranny with 3500 lock-up converter(BC-Auto)
one piece 4" aluminum driveshaft
3:55's with trac-lock
AIS stage II progressive dual nozzle meth kit
LMS double x exhaust
addco sway bars front and rear
Custom paint
Boyd Coddington smoothie II's 275/35r18 front 295/35 rear
sensor lowered
future mods:
re-run lines and clean up engine compartment
new fuel rails(if i can find any)
imrc deletes
new exhaust
re-tune after Boscabel meet
re paint
black interior
The Mark
1998 Lincoln Mark VIII LSC. 5.0 Forged DOHC Stroker Teksid Aluminum Block. B Heads with 96-98 Mustang Cobra Cams. Vortech T-Trim Centrifugal Supercharger with 3.33 pulley. 17psi @ 7150 rpm. Custom Air to Air Intercooler with two blow-off valves. Current Street Configuration: 492rwhp 421rwtq.
http://www.streetfire.net/video/the-mark-all-done_210647.htm
http://www.streetfire.net/video/sshs8-the-mark-1175112080_197859.htm
Major Mods/Repairs/Parts done to The Mark:
136-2261002 Baer Eradispeed Extreme Plus 2 piece Front Brake Rotors for 1999-2004 Mustang Cobra
136-2262001 Baer Eradispeed Extreme Plus 2 piece Rear brake rotors for 1999-2004 Mustang Cobra
1998 Mark VIII Alternator
1998 Mark VIII Collector Edition Wood Shifter
2 1/2" Custom mandrel bend SS exhaust
8 Bolt Flexplate 2004 Mach 1
97-03 Mustang/Cobra Electric Fan
97-98 Mark VIII Steering Column
9904HABA Front Hub and Bearing Assembly for 1999-2004 Mustang Cobra
Aerospace Crankcase Evacuation Tank
American Air Suspension 1 ½” Lowered Coil Spring Conversion
ARP 2000 Bolts
ARP High Tensile Strength Head Studs (with 12 pt nuts)
ARP Main Stud Kit
ARP Racing Front and Rear Extended Wheel Studs
Assorted Silicone Couplers
Assorted T-Bolt Clamps
ATI 10% overdrive 8 rib balancer damper
Bend Door Actuator Motor
Billet Modular Crank Trigger
BR57B Rear brake pads for 1994-1998 Lincoln Mark VIII
Bradshaw Bros. Custom built 500 rwhp racing 4r70w transmission
Classic Tube SS Brake Line Kit F&R
Complete Ford Engine Gasket Kit
Custom built Ford plate style trans cooler w/SS braided lines
Custom Forged Boze Wheels Front wheel dimensions: 18x8 w/ 6.375 back spacing
Custom Forged Boze Wheels Rear wheel dimensions: 18x9 w/ 7.500 back spacing F&R Wheel Spacers - 1/2"
Custom Manley Pistons-off set
Custom Polished Aluminum Intercooler Tubing - 3 1/2" intake, 3" discharge
DP31031C EBC Brake Pads for 2000 Cobra R/Brembo Brakes
Dynotech Metal Matrix Drive shaft
E9DZ1215A Rear Wheel Bearing for 1999-2004 Mustang Cobra IRS
Earls -12 Pro-Lite black hose and misc -10 & -12 black fittings
Ed's Rear Caliper Relocation Kit
Enlarged 2 ½” SS Pipe Modified Stock Mark VIII Exhaust Tips.
Federal Mogul H Rod & Main Bearings
FOMOCO-1R3Z6L253AA - Timing chain guides
FOMOCO-1R3Z6L253BA - Timing chain guides
FOMOCO-1R3Z6M256AA - Timing chain guides
FOMOCO-F3LY6K297A - Timing chain guides
FOMOCO-F7LZ6K254AA - Timing chain tensioner for 4.6 4v B Head
FOMOCO-F7LZ6K254BA - Timing chain tensioner for 4.6 4v B Head
FOMOCO-XR3Z6B209DB - Steel tensioner recall kit for 96-98 Mustang Cobra
FOMOCO-YR3Z14300BA - Mustang Cobra/GT Pos and Neg Battery cables
Ford GT supercar fuel pump
Ford Mark VIII Custom Fitted Car Cover
Ford o2 Sensors and long lead 4-wire for headers
Ford Outer Tie rod Ends
Ford Racing 410 gears
Ford Racing Aluminum Radiator 03/04 Cobra
Ford Racing deep well trans fluid pan
Ford Racing Trak-Lok Diff
Ford Upper Control Arms
Front – 235/45/18 Pirelli PZero Nero
Hub Dust Caps 2004 Mustang
IMRC Controller 96-98 Mustang Cobra
Injected 302 Stroker Kit
Kenne Bell Boost-a-pump
Kooks 3/4 Headers
Lower Radiator Hose 2003 Mustang Cobra
M2300X Ford Racing/Brembo 13in 2000 Cobra R Front Brake Kit
MAF Plug for 2005 Mustang GT
Magnaflow high flow cats
Magnaflow polished SS mufflers
Manley H-Beam Rods
Melling High Volume Oil Pump with Billet Gears
MET-MBR0004 - Screw in type valve cover breather modified and welded bung to accept -10 Earls 120 deg hose end
Mustang GT MAF for 2005 Mustang GT
Myron-Davis DVD player
NGK BR7EF Spark Plugs
OEM-MC-PW470 - Water pump for 96-98 Cobra
Percy Header Gaskets
PI multi disc 3600 stall torque converter
Pioneer in-dash navigation system and multi-media head unit
Pioneer Ipod Aadapter
PMAS HPX Slot Style MAF
Polished 96-98 Cobra Intake
Polished ACCUFAB Single blade throttle body
Polished Treadstone Intercooler TR10 24in Long core
Poly Diff Bushings
Raxle SC T-Bird rear half shafts
Rear - 265/40/18 Mickey Thompson ET Street Drag Radial
Refresh Cylinder Heads
S&B Cone Air Filter 4” Inlet
SCP Pinion Brace
SCP Rear Cover Brace
SCT Xcal2 Flash tool
Siemens Deka 60lbs injectors
Strut Bar Bushings
Sway Bar End Links
Throttle Cable 1999-2001 Mustang Cobra
Throttle Cable Bracket 96-98 Mustang Cobra
Total Seal Stainless File Rings
TPS Sensor
Two Vortech Maxflow Racing bypass blow off valves
VMP MAF adapter for 2005 mass air flow sensor into aluminum tubing MafXtender
Vortech Idler Pulley – Upgraded Newest no squeak version
Vortech Supercharger Tuner Kit
Vortech V-2 T Trim Supercharger Compressor Polished with Heavy Duty Bearings
Wheel Alignment
YR3Z1109AA Rear Hub for 1999-2004 Mustang Cobra IRS
Just another 1996 Mark Vlll with a KB 2.2L Inter Cooled set up on Forged Internals, with "C" heads. Complete front and rear sub frame ties, with poly upgrades. 3:73 Gears with Eaton posi unit. Kooks headers with 3" collectors and full 3" SS exhaust thru Magna Flow Race Mufflers and dual 3" in and out resonator. Focus Fuel pump, Aeromotive Fuel rails and regulator. 60 lb injectors. Fully built trans with Marauder TC. Running on 18" Cobra Stars and BFG's.
YouTube- Silver Streak becomes a Whiner
hadn't seen the new wheels yet roadboss, look good
Intercooler: None
Boost: 16.2psi
Power: 384/398
Timing: 8*
Heads: Stock
Block: Stock
Tune: SCT
Gears: 3.73
Trans: Stock
Lower boost
Relocate IAT sensor
New coils
Soon mods:
Meth injection
Intercooler: None
Boost: 16.2psi
Power: 384/398
Timing: 8*
Heads: Stock
Block: Stock
Tune: SCT
Gears: 3.73
Trans: Stock
Lower boost
Relocate IAT sensor
New coils
Soon mods:
Meth injection
Hi Bill I have the same setup as you and am having a couple issues could I ask u a few questions
I'm the process of a tiny lil 1.5 kb install. I have a question for you kenne bell guys. Looking for some aftermarket fuel rails and wonder what options I have. I kinda don't want to spend 3hundo on aeromotive ones. Are there any other cheaper oprions for me? Or anyone have a noce that that can be painted? Lemme know. Btw I felt like a bada$$ until I saw all of your blown cars. Gives me something to strive for.
Yeah it sucks but it's been sitting for almost 4 years and I need the money. The body's in rough shape I'd like to just sell it as a whole but if I can't get what I want I'm just gonna part it out I have a lot of parts in it.
what are you looking for for the package. if you do part it out, how much for the headers
I'm gonna start a thread later so we don't blow this one up with my stuff but the headers are probably the one thing I'm not gonna screw around with so sorry unless you want the whole chassis
I'm gonna try to sell it as a whole first but if I don't get any bites within 2 weeks then I'm gonna start parting it out
I figured I'd post some pics of my friends long gone 97 Mark. He no longer has it though. I helped him pull the engine and the front bumper cover was sold, then the body was sold after I got the Cobrastars & LSC side moldings off of it for my 95. I also bought the entire exhaust system and some members from this site and from MarkVIII Enthusiast Community on FB bought many of the parts from the motor but anyway, this is what it looked like. I'll try to list what I can remember as I post each pic.
2004 Cobra front dress/inter-cooler, ATI damper, quick change lower pulley
WHIPPLE 2.3 2004 cobra cams, GT500 type cam followers
2001 GT 4R70W completely built. 5.4 planetary, Edge 3000 blower converter
BBK intake, Aeromotive fuel system
METCO quick change lower pulley with stock size pulley ring, ATI balancer for 2004 cobra accy drive.
4.6 DOHC supercharged forged rotating assy
All new accy. drive pulleys/tensioner, Ford racing water pump, Moroso power steering tank
2.3 polished whipple 15lbs boost
SCT big air 2400 MAF, BBK intake tube, Accufab throttle body, Ford racing wrinkle blue cam covers, 8-AN fuel line, billet filter
Melling billet oil pump, ARP head studs, 8:1 compression
Manley rods/pistons ARP bolts and head studs, 97 Cobra block, 2004 Cobra forged crankshaft, steel rings, Canton screen windage tray
ARP main studs, H beam rods, balanced forged bottom end.
remote filter/braided lines, ceramic coated headers &
7quart Canton aluminum drag race pan.
Kooks headers, TEKSID block, 2001 Cobra ported heads,
SFI 8 bolt flywheel
Gauges inside and the "cruise OFF" button was used as the nitrous button
notched/braced cut out for Canton pan
thanks to Doug DLF @ LOD for the instructions with the conversion and steering components.
Paxton regulator/braided lines
60lb Siemens/Deka injectors, GT500 coil covers, Accel coils, iridium X plugs
2.5 mandrel exhaust
3.73 carbon fiber clutch pac rear,urethane bushed diff.
Temple Performance bumper
2010 GT500 heat exchanger/I.C. pump
19" wheels and I don't remember who made them. He put them on another Mustang he bought. He did have chrome Speedstars on it before these. He gave me the Cobrastars and LSC moldings for free. Since we had the same color car, they matched mine perfectly on the 95.
THE END!!
