mlara1129
interesting.
Pressing the control once will disable the AdvanceTrac stability
enhancement and the engine power reduction portion of the traction
Driving enhancement feature; the brake portion of the traction enhancement
feature will still function normally. Pressing and holding the control for
more than five seconds will disable the AdvanceTrac stability
enhancement and traction enhancement feature.
That's not confusing.
BEFORE
AFTER
Very strange. A simple push of the button turns mine off completely. I can drift to my heart's content with a single push of the button.
The manual for the 1st Gen only says to push the button to turn it off.
BTW:
Since you put that new custom CAI and the new sized wheels, you did disconnect both battery cables for 15 minutes and touch the + & - cable together as member jrand suggest to reset the KAM setting and let it relearn ?
might as well ...
I can't drift in my car because the Brake Assist kicks in.
Pressing the control once will disable the AdvanceTrac stability enhancement and the engine power reduction portion of the traction enhancement feature; the brake portion of the traction enhancement feature will still function normally. Pressing and holding the control for more than five seconds will disable the AdvanceTrac stability enhancement and traction enhancement feature.
With a single push of the button I can get sideways at will.
Hmmmmm..... Page 225:
and does Will appreciate it when you come at him sideways like that ? hahaha lol, thank you, thank you, I'll be here all week.![]()
That depends if he sees me or not!
I tried holding the button down for more than 5 seconds (actually, about 15 seconds) and the message center beeped and said AT on. After that I couldn't turn it off at all; pushing the button did nothing until I shut the car off then on. If I hold the button down for 5-10 seconds then release it the message center says AT off.
I have an '06.
did this test... and came up with the results...
push botton (no hold)- trac is off, heavy foot no spinning of tires.
push botton (hold) - trac off, heavy foot, no spinning of tires.
