It's all stuff that's been done before. Nothing earth shattering.
I'm thinking of going a shade darker. Can we be twinzies and cruise around Ill noise?
Here is a pic of my 2004 Ls. It is a dark blue. Just rolled over 90k. Still have plenty of plans ahead, but just tint and a system in it for now. Was wondering about if I could get some wheel suggestions. I don't know if i should lower it then 18s, or maybe go bigger. Just want a real slick, quick cruiser. Thanks in advanceHow did you chew through the rears? iydmmaYeah, chewed the rears, got a flat and to top it off one of the ASA's welding cracked![]()
By using the go fast pedal!!!!!!![]()
Man, I drive mine pretty hard and I don't burn the tread off like that. Mine usually dry rot and develops cracks in the sidewall first. I'm looking for a matched set of takeoffs now for that reason. You probably have some neg camber in there though which would be understandable.By not replacing my tires before they became slicks. Replaced the fronts not too long ago because I had staggered setup and took too long to replace rears.
Dirty but couldn't stop myself.
