Marc---
WHAT IS IT???
KS
Purolator oil filter.
Marc---
WHAT IS IT???
KS
but the rubber gasket stuck to the block when I took it off, I spewed oil everywhere on startup because I didn't notice the gasket stuck to where the oil filter seats itself. Scared the :q:q:q:q out of me.
i did this too. u better believe i look at every old filter i take off now to make sure that gasket is still there. what a mess that made. :frown:...
Also, spread some oil on the gasket on the new filter to make it less likely to stick on when you remove it later.
My father taught me a long time ago to always reach up and feel all the way around the mating surface on filter adapter (part on the engine) to make sure that there weren't even any pieces of the old gasket left on there. If you do that, there's no point in looking at the old filter. If you just look at the old filter, you might miss something.
