OK, having a problem, engine light
CoolCee1
Philadelphia
Was traveling I95 south, went to passed some one, engine light started to flash , vehicle hesitated a bit, put it in nuetral, turned it off, and restarted, lights out! Went to pass again same thing happend! Now engine light is "on" This happened once before in the pass, it was two of the ignition coils, is this a constant problem with the Lincoln LS(mine is a 2004, V8), only 72k, treat her well!, also are there any upgrades for the Trans!!!????
US Army!!!!!:cool:
Well i'll change all 8, any good ones on Ebay?, by the way, what type of soarl plugs shoild I used, might aswsell get that out the way!!!?
You can try ebail coils if you low on cash but I would say stick with oem coils.
Yeah, stick with OEM. If you want to save money just find the bad one and change it; Just be prepared for another one to blow occasionally. Eventually you'll get them all :)
Any upgrades on Trans, would like to give car a little more pep!!! It has a cold air intake sounds nice, the wistleing sound!
