trueblues700
Hi everyone,
My name is Joey, I'm 27 years old and I have a Lincoln LS V8 200. Ive had it for about a year now used and recently had a problem with overheating. It keeps leaking radiator fluid. The fluid leaks from underneath the brake booster somewhere. I had brought her into the shop over 4 times and the problem still stands! It would work fine for a couple of miles then back to overheating. They changed the thermostat, tightened hoses that blew off because of pressure building up, new cap, new housing cap, new thermostat housing, got flushed, pressurized and looked over several times again. Still, overheating though! Thats the main issue.
Theres also a battery problem i believe. Ive had this battery brand new now for about 8 months but every time I need to go somewhere I have to jump it. When I shut the car off, it completely dies, COMPLETELY! Then I have to jump it again. I bought a kill switch for it and it helped for a while but was short lived.
The left window shows an E for the gear I'm in sometimes.
I have the "Phantom Beep" every time I have the "Check Transmission" info come on in the information window.
Other than that the car runs great!! When it wants to. Please help if you can..
-Joey
-Joey
