Fundy1842
So I have perused the forums about the regulator problem on the windows, and have reached an impasse.
Driving home from work today, I rode with the windows open, and when I got home, I tried to roll the windows up, and much to my surprise, I simply got a "crunching" sound from the passenger door, and no window. So I looked through the forums and found that this is a common problem with the LS (mine is an '06). I saw that it is most likely the regulator but it could also be as simple as replacing some plastic clips. So I decided to take a look.
I managed, after trying to gingerly remove the door panel, to rip the damn thing off and get a good look at the inside of the door. Much to my surprise (because I had not read about it) I found a "sound proofing" layer of foil like material underneath the door panel. I managed to peel most of it off on the right side of the passenger door (towards the back of the car), and found that the window is intact, and that the wire for the pulley seems to not be tangled as I had previously read.
My question is, what exactly am I looking for to determine what the problem is with my window? I am sure its not the motor, because when I push the button, the motor turns and tries to pull the window up or down. The glass is not broken (which i thought was the cracking sound when i pushed the button). but the window seems to sit lower in the door then normal. i suppose i will take the car to the autoglass place near my work tomorrow, but now that i have the panel off, i would like to diagnose it myself.
what should i be looking for with the panel off? is it okay to peel the "foil" layer off of the door? if it sacrifices a little bit of the sound dampening, i dont care if i can fix the door for less than a few hundred dollars. even so, is this foil layer something that i can replace?
thank you as always for your help, i cant tell you how useful and productive this forum has been for me.
i look forward to your help.
