I looked at the PCM to try and find the catch code and I found X3L2, is that a valid code?
The car was made 10/92 so it should be one of the first Mark VIII's... cool info about the octane pin, I think i'm gonna leave it alone though... not gonna try and hot rod this Mark too much, just keep it clean with a few minor mods.
So what do you think I should do as far as chip goes... I just need a basic program, mild shifts, 6500rpm shifts, timing retard removed, top speed limiter removed, fans turned on earlier, a little but more timing and leaned out a bit at WOT...
Tiffany's 93 was the 515th off the production line and it had the w2z3 PCM.
Is CTE1 a valid catch code for a 93?
So this PCM is commanding 32 degrees of timing at WOT? That's more than I run in my 98 with my Sniper Tune lol
That right, Tommy, or did you mean W3Z2?
Anyway, mine just for giggles:
Date: 01/93
Production number: 78805
Catch code: W3Z2
Date: 01/93
Catch code: W3Z2
