Pioneer Appradio 3 install
every once in a while, I run into a car that just behaves slightly weirdly, go ahead and follow the button remapping procedure and that usually clears it up. best part of the ASWC is that you dont reall need to take it apart to do the remapping. seeing the LED is a huge help, but as long as you can count on time and follow the simple instructions, its pretty easy.
forgive me, I dont have the instructions with me, but i did it at work today...
I believe its (double check since you will need the button list a could of pages back further)
(first turn the radio off with its power button the turn the key off)
turn the ignition on, within 20 seconds press and hold the volume up button for 20 seconds (i would give it an extra one or two to make sure since you cant verify by the LED)
volume up has now been programmed
then one by one press and hold each button for one full second in the order of the list in the instructions
press and hold vol up for 1 sec if you need to skip a feature on the list
once all buttons have been programmed, press and hold vol up for at least 10 seconds
done
So today I connected it up to my phone using a OTG adapter and manually remapped the buttons using the new Axxess Updater App.
Worked like a charm, problem solved :Beer
Staff online
