LsUnV2
how much splicing??? i was under the impression that the harness supplied would take care of most of the wiring then jsut the ground power?? do you have any more detailed pics of what you did
Keep in mind that you have to connect the aftermarket harness to the radio harness. So that's where all of your connecting speaker wires etc. comes into play at. Trust me real simple, the instructions with the radio tells you which wires are what and then there will be a diagram for the aftermarket harness that tells you which wire is which. If you saw my install pics, you noticed that I installed my gps antenna in the rear deck on my third brake light. I mounted the microphone right above the steering column. It clipped right on perfectly, looks as if it belongs there.
