Ankur104
Hi guys,
I want to buy 19x8.5 with 245/40/r19 with stock ride height for now and preferably with a concave look to them. I have researched you can do a 35mm-45mm without a problem depending on width of rim im assuming. My question is if a do a 8.5 wide rim with a 35mm offset and the above tire size, will i have rubbing issues when installed and/or when i lower the car later? I figured 35mm will be the lowest offset i can go to have a concave look to them. Here is the link to the wheels i want to get, ignore the bolt pattern because the dealer said he can get them in 5x108 for me.
http://www.ebay.com/itm/19-GROUND-F...Parts_Accessories&vxp=mtr&hash=item27db95aee1
