Don Pfau
A little over a year ago my 1993 Supercharged Mark VIII started taking moments that it would spit and sputter a little while cruising and occasionally stall at a stop. The problem comes and goes but keeps getting worse. We have replaced the Crank, MAFS, and Cam sensor. We even replaced the electric fuel pump even though fuel pressure has always held good at 50-60lbs ?? But it actually ran good for a little while after that but the problem quickly came back and even worse. We have checked all the grounds. pulled and cleaned the computers SCT chip. Changed plugs a couple time. Checked a lot with carb cleaner looking for a intake leak. No codes. All Sensors checked are reading normal. Any Ideas ????
