power steering pump
Dazedust
Greenbelt
How do I change the power steering pump? Where is it located on the engine? Is there directions somewhere on how to change???
Here is a pic of the engine removed. The power steering pump is removed, but annotated as to where it belongs.
Also....here is the procedures directly from the manual:
Steering Pump, Power
When replacing or removing the power steering pump, one of the two following procedures must be followed. If no jack or hoist is available to raise the front wheels, use Procedure No. 1. If front wheels can be safely raised off the ground, use Procedure No. 2.
Procedure No. 1
The replacement power steering pump must be primed with the specified power steering fluid prior to installation in the vehicle.
1. Remove the fitting from the pressure port and pour power steering fluid into the pressure port with the port facing upward to maximize the amount of fluid added to the power steering pump.
2. Turn the pump driveshaft slowly and continue to add fluid.
3. Install the power steering pump in the vehicle in a manner that does not allow the fluid to escape from the power steering pump.
4. Attach the power steering lines to the power steering pump and power steering pump auxiliary reservoir.
5. Fill the power steering pump auxiliary reservoir to the proper level.
6. Start the engine and allow it to run for several minutes.
7. CAUTION: Do not hold the steering wheel against a stop for more than 10 seconds at a time.
Rotate the steering wheel fully left and right, from stop to stop several times.
8. Turn off the engine and check the fluid level in the power steering pump auxiliary reservoir. Add fluid if necessary.
Procedure No. 2
1. Install the unprimed replacement power steering pump in the vehicle.
2. Attach the power steering lines to the power steering pump and the power steering pump auxiliary reservoir.
3. Fill the power steering pump auxiliary reservoir to the proper level.
4. Purge the power steering system of air.
Be sure to change the Cam sensor if you are changing the power steering pump. It is a cheap part worth changing since you will be in the area.
