Project06LS
Actually... I may have misread the question completely.
New response:
Sometimes the edges of the pad backing plates have a lip or "edge" on them due to the way the steel is die cut.
It takes a bit of custom fitting, but the edges should be filed down smooth enough for the brake pad to fit in the bracket with the anti rattle clips on the brackets.
Took a little bit but eventually I did end up doing exactly what you said and filed down the ends to get them to fit, thank you
