FreddyTovar
Hi Guys. I have a 2001 LS V8 with 115,000miles on it. 1 1/2 months ago my secondary tensionary broke and had to replace it. 3 weeks ago the secondary chain busted and had to redue my valves, replace the chain and also replace a timing chain guide. I put it all back together but the chain is still making noise. I opened it back up and the chain was loose because I forgot to pull the slack off. I fixed that I pressed the chain counter clockwise with a screwdriver and had my buddy tight the bolts. It seemed to work no slack what so ever. I put the car back together and the same problem. I reseted the primary chain tensioner with the paper clip and pushed it back in, but same noise. Any ideas of what I am doing wrong anyone? how can i test the tensioner if it is getting enough oil pressure to open back up. I have not taken the engine apart again and wont until I can figure out what exactly I am doing wrong. Thanks a lot, Freddy.
