97MarkJA
Where did you get the LED bulbs for the interior?
SuperbrightLeds.com
I did dynamat the door skin and inside of the before installing the panels as well as my components, the tweeters are in the factory locations. I ended up painting the dynamat around the speaker flat black so you couldn't see it through the grill.
ive already sealed my entire trunk. ill be doing inside the cab soon. did you do it 100 percent. if so how much did you use. im hoping i can get away with 100square. as it took nearly 50square to do the trunk.
Updates? :monkey:
Need a fix I'm jonesing
I'm too dam old....
I need to see this thing in person, great work!!
Thanks..That is incredible. You must be really proud to see it installed and working properly!!
This is going to end up being the absolute cleanest Mark VIII on the forum, PERIOD!
Thanks! I'm working on it.. I've seen quite a few others on the board that are hard to beat.
I've even seen some GEN 1 cars I wouldn't mind having.![]()
It will be different for sure.![]()
I picked up a low mile builder motor along with forged internals and a set of diamond 11:1 ceramic top, teflon coated, 4 valve relief, with tool hardened pins.
The block and rotating assembly is at the machine shop right now.
Looking to complete the mechanical pieces this coming spring along with
Any news from Fargo....ya know...
This short block has me pumped, N/A it will be a beast.
Boost it...forgetaboutit.
Fargo...lol
-O.K., we'll go get some f@cking pancakes and then get laid. -
Got the other side done, just waiting on a couple of relays.
Tail light 2 - YouTube
Cops are picky as hell in Miami. That sequence you have would probably get me pulled over in this city. Needless to say it looks so damn awesome.
