Put Wrong Fuel in it
AngieT
Jesup
Can anyone tell, I bought a 2002 Lincoln LS and it was low on fuel and I put 87 Octane in it on Friday night and then sat when I went to drive it and filled it up with 87 Octane, Well friday night it did not skip, but sat it would skip when you got to 45 to 55 (we thought it was overdrive not kicking into gear) but then this morning I went to town and engine light come on and I started reading the manual and it said I was suppose to put 91 Octane or Higher!!!!
Can anyone tell if it will mess my car up and why light would come on and blink!!!!
Blinking cel means misfire.. could be caused by wrong fuel like you say.. run a few tanks of 91+ in it and report back..
Welcome and enjoy your stay at lvc.. lol!
I agree on the pics!
ok Thanks so much, I have over 3/4 of a tank do I need to get that out or can I add a octane booster to it and then put 91+ in
that happend to me in my millenia, i ran the car dry like it was sputtering when i rolled up to the gas station, then i put 94 octane, full tank. burned that then 91 and all is well.
Winter fuel may have something to do with your problem, it flashes quicker. I would use a good quality fuel system cleaner in your fuel and buy the better quality gas (it burns slower).
I use Marvels Mystery oil on a regular basis (4-6 oz once a month) to keep the injectors clean, on occasion I run a bottle of Lucas fuel cleaner. Some people prefer SeaFoam but I have not used that one. Once a year I run a bottle of PI cleaner made by Amsoil, it treats 20 gallons and I use 1/2 bottle spring and fall... Do this to keep your injectors with a good spray pattern and the crud off the intake valves. Use a bottle of injector cleaner at every oil change and you will have fewer engine problems.
All gas comes out of the same hose, the difference is the additives. Octane boost is added to plus and premium grades to make the proper octane. The amount I suggested is only a trace. Alcohol in gas absorbs moisture and promotes deposit formation, it also creates wear on the injectors.
I have used a full quart of 2-cycle to 20 gallons before and it cleaned some crud off the valves. Marvels oil is loaded with solvents (kerosene, mineral spirits and penetrating oil).
AS far as the same hose...not quite. Gasoline is refined to specific octane levels. Certain chemicals (ethanol is one) can raise octane but the refining process dictates what grade it is. After that the gas is fungible, meaning that it is able to meet criteria that makes it interchangeable among brands. Different brands/dealers may use detergent and other additives in their fuel mix at the distribution point.
2 cycle marine oil is not a bad thing to use as long as it has TC-W3. Add 1 oz to every 5 gallons of gas.
I dont see the point of not spending the extra $2-4/full tank to get 93 octane specially with a car like the LS
Lol i didnt realize it was a woman, i guess i would give her a pass but just in general its only a couple of bucks extra
thats whats wrong with these females today, guys arent capable of teaching them sh!t anymore so they make simple mistakes
Lol.. I only put v-power in mine.. ;)
V POWER = VARROOOM POWER
Agree with all gas the same, how do we know at the pump that premium at $3.15+ a gallon isnt just 87? Problem is now all gas has 10% ethanol they say for the environment. Surely they realize it only screws up your engine. I have always used 87 and added octane boost ($2.00 a bottle)every other tank full. NEVER had any issues, also every 20,000 miles I use Zmax.
Low octane fuel will not cause a misfire and blinking CEL (check engine light) under light load conditions. As long as you don't put a high load on the engine (don't floor it) it will run fine.
Your CEL is the result of something other than the fuel. Bad ignition coil is likely.
If you are worried about the 87. Add some octane booster.
While it is certainly true that you should always use 91+ octane gas, using 87 octane won't cause misfires unless one or more of your COPs is already marginal. COP (Coil On Plug) and spark plug replacements are in your near future. Do it now, or you will be replacing catalytic converters too.
They know the alcohol causes corrosion problems and the BTU value is lower. One of the guys I was in business class with ran a gas station and he said gas will soon be 20% ethanol. When the fuel truck delivers gas, the driver adds octane boost to the tank. In some counties, MTBE is added to meet some emission criteria. Its the same story with 'Home Heating Fuel' I mean #1 diesel, its the same stuff with Dye added for non-taxable use.
Most likely you got some water in the fuel or your coils decided to go at that time. Running 87 will not harm your car unless there are other things wrong with it.
I have run 87 mostly in my car for almost 100K miles, and I do not baby my car, but it is a daily commuter. On hot days I will get some ping under hard acceleration, but otherwise the car runs fine. Don't jump on it if it pings, or get the higher octane gas.
I have used 91 and 89 and mixed octanes to see how they react in my car. 89 seems to be the best level of mileage and no ping. 87 is a bit more economical(but is it worth it?, I buy out of habit) but will ping on hot days under hard acceleration, so usually I buy higher octane in the summer. 91+ is what the factory recommends so if you want mental comfort or peak performance, use it.
Gas will not cause a misfire unless it is contaminated or you find some cheap really low quality gas south of the border.
Winter gas may have alcohol in it like the guys said. The alcohol will cause any water in the fuel to mix better, but that is not necessarilly good since then the water goes to the engine.
I bet your COPs decided to fail and were flakey for some time before this. they can be flakey for a long time before setting a CEL code. My dealer took a week trying to find my failed COP even after a code was set. Good thing it was under warranty.
Putting new 91 octane in the tank will not be the direct cure for your problem. Clean water free gas is what will do it, UNLESS your COPS are failing, then gas doesn't matter.
If a fresh tank of gas does the job, then avoid the previous station since they may have water or low quality gas. Every dealer can get a load of bad gas or water int the tanks. Let them pump it out before getting another bad load.
If the fresh gas doesn't do it, then you have joined the COPs died club.
Just my opinions and experience,
Jim Henderson
