DarthGanja
Got a question regarding the throttle on my 04 LS V8.
So I got the ETC ENGINE FAILSAFE MODE. I take the car for a diagnostic at the ford dealer. They tell me I need a new throttle body, they quote me $1200.00 incl diagnostic. I pay them $140 and pick up the car. He tells me they can't check the coils until I fix the throttle body.
So I took off my KKM air filter and all tubes running to the throttle body to see how the TB is acting. When the car is off, I can freely move the gold plate in there. When the car is started, I can't move that plate and it does not open or show any signs of movement when the accelerator is depressed. The car revs up, but that gold plate doesn't move. If I blow into the MAF sensor, which is just hanging off to the side, the car will stall. This leads me to believe the MAF sensor is working. I know when everything is working fine, that gold plate moves when you rev the engine up.
What I'm wondering is, is if that plate is closed and not opening, because the engine can sense that something is wrong with the airflow(because I have the air filter and tubes disconnected) and it is compensating by keeping the throttle plate closed? Or should that plate move regardless of said missing components?
