Archer28
Trying to change my rear pads right now. I have the caliper off, but I cannot get the brake piston to slide back into the caliper so I can install the new pads.
Every vehicle I've changed before will slide back in with a little prying against the disc, but I'm not having any luck with this one. I've even tried a large C clamp and I've tried loosening the bleed screw while prying. No luck.
Is there some trick to getting the piston to compress?
I need to get these pads on tonight if possible.
Thanks!
Thanks!
