RigsLS
- Joined
- Mar 10, 2012
- Messages
- 7,756
- Reaction score
- 532
Symptoms: Engine Overheating and/or dripping Coolant directly behind front drivers side wheel.
Direct Cause: Old deteriorated cracked Degas Bottle.
Correction: Replace Degas Bottle with OEM part only. (p/n 5W4Z-8A080-AA)
Removal and Re-Installation aka: Re&RE
1) Drain the engine cooling system.
2) Remove both wiper blade arms and the cowl vent screen.
3) Disconnect the engine vent hose, and separate the air bleed hose from the degas bottle.
4) Remove the seven bolts and reposition the cross vehicle support.
5) Disconnect the degas return hose from the degas return tube.
down along the firewall just past the Brake Booster housing.
you can move a few things out of the way to provide easier access.
6) Remove the two bolts. (that hold the Degas Bottle in place)
7) Remove the degas bottle from the vehicle.
8) To install, reverse the removal procedure.
When the new bottle goes in, your going to find that feeding the lower hose (already attached to the new bottle),
underneath the Brake Booster, is prone to want to go underneath the Steering Shaft Knuckle (at the firewall) due to the angle.
I used a long stick about 3 feet in length guided down from near the front of the Coil cover,
pointing towards to the Intermediate Steering Shaft Knuckle at the firewall ...
... helped in pushing the lower hose upwards overtop of the Steering Knuckle.
Apply a little vaseline around the tip of the aluminum degas return line to aid in getting the new hose on.
The return hose will need a little convincing with a long screw driver to coach it onto the Aluminum return line.
The clamp on the return tube of the new degas bottle is provided in the open position and getting it to unsnap is a bit tricky
