giginfrogg
I got a slight problem with my 95 mark viii. I have the lowered suspension, from strutmasters. I also have the new rear sway bar, the heavy aftermarket one. Since putting on the sway bar when I step on the gas the rear end likes to sway side to side, at higher speeds 45 and up. Ive got new wheel bearings and all suspension parts are less than a few months old. Any ideas what could cause this issue. When going around corners the suspension kind of nestles in in sharp turns, if that makes sense.
thanks
thanks
