Rear shock mount question
I'm all out of spoons
I don't think you understand what I'm saying. The mounts and bushings that came in the box with my new rear shocks from StrutMasters were a different setup then you described. Maybe that's why their starting to make the clunk again. But yes, I understand what your saying and the way they should be put together.
So, you've got aftermarket mounts. :rolleyes:
Take your car apart, then measure the shaft diameter (probably 3/8") and the size of the hole in the mounting plate(s) and go buy some new bushings.
http://energysuspension.com/universal-products/shock-eye-bushings.html
You'll probably need either p/n 9.8126 or 9.8101 depending upon the diameter of the holes in the mounting plates.
This is a ridiculously long thread for something so damn simple. :shifty:
