Gus_Mahn
OE for my '03 LS8 top. Inboard stud is short since I had to sawsall it off.
Aftermarket Deeza Bottom
No issues with install.
Tools Needed:
Jack
Jackstands
19mm for lugnuts
8mm wrench for inboard stud
18mm wrench for inboard stud nut
13mm socket or wrench for outboard joint bolt
15mm socket or wrench for outboard joint nut
I believe the jamb nut is 21mm but I used a adjustable
Also used Kroil rust penetrant, because I live in the rust belt
Job took me about 25 minutes per side.
Stood old next to new outboard down and adjusted until the flat on inboard was equal. I won't be getting an alignment. It should be close enough.
Tools Needed:
Jack
Jackstands
19mm for lugnuts
