Joshua TheHouse Schreder
- Joined
- Mar 23, 2014
- Messages
- 17
- Reaction score
- 0
I have a 2002 Lincoln LS V8
So a friend and myself replaced the Valve cover gaskets, coils, spark plugs in about 4 1/2 hours. I figured since I was already dirty I would change the oil as well. So after I got everything buttoned up I went to start my car and it started but for only about 4 seconds then it died. I attempted a couple more times to start the car and it turns over but it won't fire at all. Just wondering if this is a common problem? I did disconnect the fuel line while changing the driver side. I also had the negative terminal off the battery during this process so do I have to use a certain key when starting it or could it just possibly be a air bubble in my line? when attempting to start it after it died I did crank it over for 7-8 seconds two times.
