2001LSV65SPD
Were there any install issues? Was the original brake fluid in the Lincolns synthetic? I plan on using synthetic when I do the swap?
I got the ceramic, but the brand was posi quiet also.
I paid for a brake fluid flush but I found a few articles on brake fluid flushing. I don't know which one is better, I just scanned through them:
http://www.airheadparts.com/page.asp?recId=90
BMW but should still work http://www.dvatp.com/bmw/diy/brake_fluid_flush/
http://www.gadgetonline.com/BrakeFlush.htm
Quick LS did a nice write up in the TECH ARTICLES, Stop Tech Stainless Steel Brake Line Installations and gives a easy to follow instructions on bleeding lines.
I have seen that one but that is for bleeding...I think we (At least I am) looking at how to completely flush out the old fluid and replace with new fluid.
Whats the advantage of ceramic pads. I'm going to get the package, but I don't know anything about brakes.
The G2 Treatment I used is the G2 Caliper Epoxy which is better that just painting the calipers. Since I was removing my calipers to add the SS lines anyway, I thought it would be a great time to get this done. After doing this, I also sprayed them down with some High temp clear coat paint from autozone. to shine them up a bit more. One warning with this...They need to dry up before putting them back on or they will still be a bit sticky to the touch. I recommend removing them, doing the G2 and allowing them to dry for several hours before putting back on. Maybe even the use of a heat lamp or hair dryer will aid in this. Unless they can bake in the sun for a while. It was a little cooler when I was doing them, so baking was taking too long and they were a little tacky to the touch.Mike, what G2 treatment are you talking about? I see you painted your's black. Nice choice.
I believe mine came via fedex...
As far as brake squeal, let me point you to these sites that explain why ceramic is preferred:
http://www.brakeworld.com/ceramic-brake-pads.asp
http://www.tirerack.com/brakes/tech/techpage.jsp?techid=88
http://www.hawkperformance.com/performance/ceramic.php
These are just a few. Remember to use a disc brake quiet substance on the backside of the pads and you should be fine. Also, remember to follow a proper brake bed-in procedure:
http://www.stoptech.com/tech_info/wp_bedinstock.shtml
He sent mine USPS. Otherwise he said UPS or Fedex would've taken like 5 days.![]()
I've read all those articles about ceramic pads. I'm sure it's probably me being too paranoid because of the problems I've read about other guys having with them. I'm sure a lot of ceramic pad users are very happy. I just didn't want to chance it, and basically relayed the other guys' complaints in one of my previous posts about brake squeal.
