rpms stumble at idle
Glad I could help. The best way I was able to find an appropriatley sized bolt was to go to a local plumbing supply just bring your TB with you and explain exactly what you need remember the bolt needs to not only be wide enough it needs to be short as well. took them about five minutes to find a perfect match. then just put somthing to keep the seal perfect so you don't need to torque the hell out of it. some high temp silicone would be great. You may need to pull your battery cable to clear the code or go to autozone and have them clear the code with thier scanner I'm not sure it will go away on it's own. good luck and let us know how it ends up........... even better since many don't know about this you should take some pics of the hole and the fix when the TB is off the car.
Good point, I'll try to do that this weekend.
