RWHP numbers, what do ya got.?
Lonnie said:
Nice numbers, what compression are you running? Let me know if you need a trans to hold up to it. So far we haven't found anyone able to blow up our Stage 3 or 4 yet. And looking forward to a twin turbo setup to test the Stage 4 here soon. With full lockup and our Stage 3 TC we have a Bullitt running 10.17 @ 134mph. If he can keep the heads on it should be in the 9s here shortly, 580 rwhp. This is with the Stage 3 trans. He droped over a full second going from a TKO to the auto.
What special work goes into the body of a stage 3 and 4 Lonnie?
You're expecting 9's with 580 out of that mustang huh.. I'd like to see that! (no sarcasm, more out of curiousity from what I've seen so far, you must be tuning the car pretty good.)
Cbecker1994Vlll said:
on motor
368rwhp
345rwtq
on 150 shot
471rwhp
440 rwtq
on 250 shot
578rwhp
5.0l stroker kit
forged bottom end (Duh)
medium intake and head porting nothign to crazy
comp cams xtreme energy x262ah cams
dual shot nitrous 150 and 250
4.10s
tranny
yadda yadda yadda
Excess Nitrous is hard on a motor.. even a built one. Everything makes sense when someone says they've run nitrous, and a 250 shot is nuts Lol.
That's totally proprietary. This is my bread and butter so I'm not about to give out how we do it. And yes it will be in the 9s once he gets the latest head problem taken care of. This car is totally streetable also. He drives it almost daily to and from work.
http://www.bullseyetechnology.net/1017_134.wmv
yeah i know its hard on the motor thats why we are kinda starting to lean on takeing off the 250 shot and strapping on a KENNE BELL or PROCHARGER d-1sc
and thank you i pride myself on being a little nuts:D :D
How much torque at the rear wheels are you making on the 250 shot?
I didn't mean to ask a question as it came out, I didn't know it was your 'bread and butter'.. I apologize!
That stang sounds awesome, it lost a tenth or 2 hitting the rev limiter
Ponie,
not a problem. I'm the owner of Blue Oval Chips. Besides reprogramming, mods, swaps and installs I also now provide custom transmissions. After experiencing 2 failed (so called bullet proof) trans from another shop myself. Then seeing numerous others spend their hard earned cash on so called built trans that failed or they didn't get what they paid for, I decided that there needs to be a real performance 4R70W available to the people. I teamed up with 2 others that are in the TC and trans business. We spent over 2 years tearing down failed built trans from various companies to evaluate them. You would not believe the number of trans we found that were actually just a stock rebuild with some kind of shift kit installed. We then built several versions, tested them and re-evaluated until we came up with something that works. Then we put them behind engines in hopes of something breaking so that we could figure out the limits and offer various stages.
Cobra,
I didn't do the track programming for that car so I can't say if it's the rev limiter or it's the problem that's plagued this car for awhile now. More than likely it's the ignition problem. The ignition keeps breaking up at the top end even on the dyno. Upgraded the whole system, different plugs, less gap and still have it. Found the Granatelli COP were failing and they sent back the latest version. That worked for a couple pulls and now it's back again. This is why the heads lifted last time.
Lonnie.......
Looks like you should own the market with that type of dedication.!
You wouldn't have a 3.55 pumpkin laying around would you? Totally off subject but I'm looking for one within the next couple weeks hopefully. Came to mind.
I should send you a pm, have a couple q's about SCT.
