satellite radio
The Sirius antenna is very small; not much more than 1.5 inch square and maybe .75 inch tall. Mine is mounted on the rear air deflector of my Lincoln MKX.
you can just set it in the front or rear dash and it will work fine, no need to ugly up the outside of the car
I had mine sitting in ashtray area
I tried it before on the dash in my girlfriends car and it would loose the signal mostly going north. I'm not sure i want to do that. I just remembered that the new car kit i bought came with a piece that clips to the car antenna I'll have to see if i can put it on the antenna inside the trunk.
