My 2005 LS just turned over 100,000 miles & I am beginning to think it is falling apart. Had a problem with the car heating up the other day. Turns out it was about 1 gal low on coolant. Is there a low coolant sensor as most of my other cars have one. The temperature gauge was always normal so I never checked the coolant level til the overtemp light came on and the gauge was pegged. Shut the engine off immediately, popped the hood and the engine did not seem hot. Turned ignition on again and temp was normal. Started engine and red light went out. Drove a few miles and had the same thing reoccur. At this point discovered the low water and refilled system. Temp seems to be normal now.
After adding coolant and bleeding the system, my dccv is acting up - hot on driver's side and cold on passenger. Also, I get a service parking brake indication.
What needs to be serviced on a parking brake?
Thanks,
Joe
Thanks,
Joe
