Anyone who has read this thread should read the paragraph below. The specs of most of our wheels are such that they leave no room for a worn out front-end. If your control arms (Most common problem related to OUR wheels rubbing) have any play in them they need replaced. When you bolt a wheel on your hubs this is a RIGID piece of the suspension. There is NO LATERAL MOVEMENT ALLOWED PERIOD...ZERO MOVEMENT...Clear enough?? So if the wheel clears when you bolt it on. That same exact clearance, with respect to the wheel and the control arm, should be exactly the same in a full lock to lock turn. OBVIOUSLY the deflection of the tire itself is another story. However the tire should also be in the exact same position with respect to the control arm itself. If anyone has any questions please hit me up with them here, PM or email...
There is NO PROBLEM WITH THE FITMENT OF THESE WHEELS!!! You DO NOT NEED TO GRIND YOUR CONTROL ARMS TO MAKE THEM FIT. Anyone who wants to debate that fact is welcome to weigh in on the subject. But you best have your ducks in a row...
Cheers Everyone,
Brad
