M
		my95mark8
Guest
How many of you use snow tires? My dad owned the car before me and he says he never had any trouble in the snow. I came across some nice Goodyear snow tires, I am thinking of putting them on.
			my95mark8 said:How many of you use snow tires? My dad owned the car before me and he says he never had any trouble in the snow. I came across some nice Goodyear snow tires, I am thinking of putting them on.
MrWilson said:You only need trac and weight if you cant drive,jk.
IMO you just need them to be able to move.
Jibit said:Never used snow tires and I have always drove rwd cars. Its all a matter of your ability to drive and how cautious you are. I think snow tires are just as bad as having 4 wheel drive, its a confidence booster and then you end up in the ditch! Personally, its snowing and I'm still driving with d/r's! Stopping is a bit scary but I can handle it
67Continental said:spoken like someone who doesn't have to deal with "real" winter
MichiganTeddyBear said:Yea, I hear ya over there in Canada Land... Get pretty nasty ones here in NW michigan too.
Snow tires and 4WD in the wrong hands definately does not improve the ability of the vehicle to be maintained in a controllable manner. They are an AID, not a CURE for the slimy roads. Still gotta use the thing stuck to your shoulders by your neck in order to stay outta ditches and remain safe.
I have 4wd on my Jimmy.. even with it, I dont go flying around on the roads, up here I see more 4wd vehicles in ditches than 2wd... I use the 4wd to help when I need it (usually the old beast is left in 2wd) to get me going... I don't count on it for additional control (I actually loose some steering ability under accelleration with it in 4wd). Of course, I do take it out into the 'wild' now and then a go nuts with it, but never on the roads. Also, at least on my Jimmy, when in 4wd.. ABS is comprimised (not disabled, but not as effective), so if I where to need abs for some reason, it wouldn't be there when I need it.
 Its tires are definately frozen right now.. (cold, windy, snowy as I type this).. even after my plow guy did my drive, ect. today, I went to move it back into its spot, and almost didn't get there!  It actually seems to do better with a little bit of snow on ground...  Just keep it away from ICE (same with Jimmy).
   Its tires are definately frozen right now.. (cold, windy, snowy as I type this).. even after my plow guy did my drive, ect. today, I went to move it back into its spot, and almost didn't get there!  It actually seems to do better with a little bit of snow on ground...  Just keep it away from ICE (same with Jimmy).  67Continental said:spoken like someone who doesn't have to deal with "real" winter
