roncoinc
every epoxy is a mixture of chemicals... you can change the ingredients which will change the epoxy, and you can even change just the precise ratios those chemicals are will have an effect on the end epoxy.
there is a big reason that there in not just one single type/brand of epoxy out there.
of course it could, if the correct epoxy was mixed wrong, it may not do its job, if the incorrect epoxy was used it may not do its job... too many varibles in there to say that it couldn't be a factor.
You are correct on that of course.
my thinking was if somebody was making a coil there would be no reason to not use a proper epoxy.
if it was used then not a factor.
If bondo was used then,,,,,,,,,,,,,,,,,,,,
