PennSt8_nuc
2001 LS V6 107,000 mi
So I just had my pcv elbow and upper radiator hose replaced by a local shop. When my wife got home with the car it was squelling from the front of the engine, likely the belt/pulley area. It was not doing this at all before I took it in. Is it possible that coolant has gotten on the belt causing it to squeal, or maybe the coolant system is not properly primed? The squeal is there quietly at idle but increase quite a bit with RPM. It is very noticable but of course when I called the shop at 7:30 this morning their technicians had not noted anything on the records. Any ideas. Thanks in advance.
