Sst
Matching as in the red line? Lol
no he means matching the engine speed to where it needs to be after the shift. its not really something you can do with a clutch less trans. and not having a clutch is why the SST works/feels to bad when compared to a manual car
Umm I use the highway everyday. I need to pass the morons. I wanna use it. Is there like a tutorial video or something?? Tried using it and almost had a heart attack. I'm sorry; I got this car and still don't know 100% about it.
as far as on the highway, its pretty much useless, you would probably want to the car to down shift twice instead of downshifting once then downshifting again to get to the right gear to pass. your far better off to just leave it in auto and then just get in the gas let the car do what it wants to and then pass.
as far as how to use it, just go and drive and use it. some where with a lot of stop and go. it really is as simple as start accelerating and when you feel like you want/need to shift it into the next gear, being careful not to let the RPMs get too high (too high is where the dashes turn from white to red (redline)) when slowing down, either downshift (watching those RPMs again, redline = bad) or just make sure that you are in 4th or 5th gear before you come to the stop and let it downshift for you.
Roll on with SST - Aggresive Passing
What you'll want to try and do it the following.
Let's say your cruizing along in 5D, (around something like 40-60Mph range)
- keep gas peddle steady, still and slide select over to the right for SST mode ... it will stay in 5th.
- push gas peddle down aggresively but not all the way down, maybe half.
- pull SST towards you "-" and drop in to 4th gear.
- Pin it until about a grand before redline and whilst keeping foot planted,
push SST forward away from you for the next upshift into 5th.
- back off the peddle cuz now your are starting to attract attention.
Practice this and get the timing right,
you'll notice this LS will turn into a rocket ship and boost forward.
You'll want to get the revs up just a split second before you pull back into 4th,
stay on the gas, when she shifts into 4th, follow through on the peddle,
all the way to the floor and let her get up to speed and shift into 5th to coast her out.
trying this in 3rd or 2nd is pointless and you could end up either kissing the windshield or
squawking the tires on the downshifts. road speed may be too high to try this effectivly.
Aggresive on ramping with SST - using down shifting.
same thing as above.
first portion of the bend in the on ramp, with nothing in front of you.
- in SST while in 5th rolling into the bend.
- press slightly down on the peddle, wait for it, pull SST back once into 4th
- stay on the peddle, ride it out, and drift into 5th.
- merge and bring the shift select back into Auto 5D.
off ramping using SST - limited braking
- Get off the peddle all together and lean slightly on the brake peddle.
- As road speed reduces, pull SST into 4th, ride it out, no gas.
- reduce more road speed, riding the ramp out pull into 3rd (but not too soon)
- you'll want to increase the RMP with a slight lean into the gas peddle at the same time as you shift into 3rd. not more, no less, match it!
This is something you have to practice.
Matching your RPM with road speed does not mean sitting there and watching your gauges constantly.
You have to learn the sounds and feel of the engine.
You do it wrong a couple of times and you'll learn that she'll want to go into 3rd with an aggresive slowdown to the point where you
are going to kiss the windshield or lock the tires (this would be too aggresive and takes it's toll on the tranny in the long run)
This is not something I can give you RPM or road speed numbers for,
you have to get a feel for it and learn how to shift correctly with the SST.
don't use SST all day to shift around town, you're going to get distracted and not feel it right and end up shifting wrong to the point that it's a bother, just ride it in Auto 5D as normal.
Easy on the downshifting with SST while your road speed is too high.
When coming to a stop, in 4th or 3rd, (4th is good enough)
while crawling to a stop, slap it back towards you twice, and get it in 2nd.
take off in 2nd, punch it half way, ride it out and forward shift into 3rd, 4th, 5th Auto.
Don't red line it ! a few thousand below redline is comfortable and good enough unless you are trying your hardest to put that Stang to shame.
Red lining is the same as WOT and in my opinion, too much of this is only going to lead to blown valve cover gaskets,
damage to the timing chain & tentioners as well as put too much stress on the poor LS transmission.
Lastly I'll say this and others can add what ever comment they feel.
I use the SST aggresively because that's how it should be used if you want to use it correctly without slamming the gears to the pavement.
You can ride the SST calmly to but then you might aswell be in auto 5D
best of luck.
Practice makes perfect.
Ps: on this forum, there is a thread about modding the SST shifter,
it's a trick for reversing the shift. forward would then become downshifting and pulling towards you would become upshifting.
You should be able to learn the SST shifting as intended but you may do better with the SST reversed.
~ Sorry for the long post. (I love SST)
I'd rather you mean business than pass me doing 1 mph faster than me while I'm stuck behind a truck. Please, take your time as I eat whatever it's spitting out.
sure, you can dip down to 3rd if you'd like,
it's all about matching the RPM to the road speed with the gear you plan to select.
however, if I was already doing something like 50mph, I wouldn't go down as far as 3rd.
I like 4th as a good roll on.
but all road speed depending ofcourse.
Well road speed vs amount of aggression of course, but when I pass I want them to see me coming Jeepers Creepers style hahaha
ok so what if you're racing, again not that i do that, and want to do like a 40 roll or something
Hmm, I would think 3rd but I've never really thought about that. I would imagine second wouldnt have enough left in it at that speed to be worth your time.
be in 4th, step on gas and pull down a gear.
pin it and upshift.
~ something like that.
pin it and upshift.
Yeah that sounds right to me. Never done it before though. All my little races have been at a certain two lane intersection with about a quarter mile to the merge. Beat a SHO (new gen) once, not sure what the f*ck that guy was doing because he should have smoked me lol
i know what to do...what i'm saying is in a case like this it would be ok to downshift even though you are not in the "ideal range for the gear you are selecting"? theres no other option if you want to go fast right? so the harsh downshift is inevitable in this case?
never driven a manual, so the guys that have can you shed some light? does this harsh downshift happen with manual's as well?
It would if you dont match your engines RPMs to where they will be when you enter the new gear. It sort of becomes second nature and you dont need to get it exact or anything, just close. I do the same thing sort of with the LS and it seems to handle it well with the down shifts. When I downshift I have a natural instinct to bring the engine RPMs up a little, which is harder without a clutch but I just sort of time the shift with pressing the gas a little more. If I'm passing a car I'll let off the gas a little as I downshift and right before/as it enters gear I slam on the gas. The LS then becomes a rocket lol. Find a friend with a manual, spend a day learning. It will make your understanding of driving just that much better (its worth the effort and time)
I'm finding its REALLY hard to explain what I do in SST lol
I've noticed that you'll want to press the gas peddle down, get it reved up,
then pull it down a gear.
if you pull it down a gear without giving it some peddle, that's when your going
to get the harsh shifting.
try it out.
gas peddle before shifting, you're bringing the revs up just a little as you shift and you continue to lean into it.
and yeah, HANG ON !!! Instant power band.
the stock sst is soooo slow. i almost always ignore except for down hill descent without brakes.
rev matching an auto is kinda not really doable. i'm just usually on the gas a little when i down shift to help bring up the rpm. how much gas depends on how long the sst decides to take. the 3-2 down shift is so slow. like, neutrals out and comes back. but its a non-synchronous shift i think, so i guess that makes some sense. but still, geez. 2-1 and 4-3 i never see any problems. far smoother.
try it out.
oh wow, duuuh. Thanks BigRig. Now that you mention it, i have done this before and asked myself "wheres the nasty thud/jerk?" and I think its bc i was giving it "some peddle."
k noobness done...for now :D
I've noticed that its much faster if you let off the gas a little as you hit upshift. Not sure why... But I agree its slow. And yeah its basically impossible to actually rev match but you can make it better at least.
I've heard with a Torrie tune the SST works much quicker, this true?
idk how the gen 1 and gen 2 differ, but I love driving my LS in SST.
IMO its much "faster," and certainly takes off from a stop with much more authority...specially with a tune. Don't know how it applies as you can tell from what i noob I am, but with the tune i can chirp the rear tires shifting into second with SST, but for some reason can't in D4/D5.
My main reason for driving in SST is that being able to control my gearing allows me to have the kind of power I want when I want it instead of the transmission guessing what I'm asking for.
Another thing I've noticed, my acceleration seems to be very unlinear. If I hoild the accelerator at 30% from a stop sign the first 2000 rpms accelerate like I want, but then after around 2k it seems to take off and start accelerating much faster. Any ideas? I was thinking maybe failing coils? Or is the LS' acceleration just that weird?
I think that's the way she is. Powerband or something right?
There's a small hill on the edge of our small campus here where I let her eat when I take her out to play.
i use it to keep the trans for changing its mind on me in a corner. not a fan of that.
the torque curve of a DOHC engine is towards the top. they don't have the small block ford low end grunt. combine the lack of low end torque, and the tight, low stall converter these things have, means it takes a bit for the car to get into the power band.
Ok, good to know that wasnt just me haha. Doesnt bother me, I was just worried it might be a symptom of something.
There is an on ramp by my job that I take it get home. Its a half mile long straight on ramp that has a 10(ish) degree slope down the whole time. Its basically a cannon. Ive hit the speed limiter a few times using that ramp lol
Yeah, that for sure. This cars slow decision making on downshifting is basically the reason I go into SST
i always drive my 05 ls v8 in sst. i love it. the ls thinks to much for its own good and the transmission can be really erratic. its great being able to control the shifts, without dealing with the clutch. I have gotten pretty good at shifting in sst, if you let off the gas a bit on up shifts and shift right when u feel the engine start to pull, usually around 3000-3700rpm for 1st,2nd and 3rd, then 3200-3500rpm from 3rd to 4th and 4200rpm into 5th.
