This forum has been a great help to me. I replaced the entire front suspension on my '95 Mark VIII without any problems, thanks to various threads on this forum. Hopefully, I can get some help with a current confusing issue.
First off, the starter appeared to start dragging, and the battery took a good charge so I pulled the alternator and took it in to test. It was shot. New alternator installed. Shortly thereafter, the car stranded me (at the autoparts store). Would not turn over at all - no click, no nothing - although everything else in the car had power, and the battery appeared fine. Jumping didn't help.
I replaced the Crank sensor, the car started up, and I took her home. Shut her down, tried to start it again, nothing. Jacked with the Crank sensor plug (cut it off and re-wired it), still nothing. Tapped the solenoid with a hammer, walla! The starter started turning again. Not fast enought to start the car, but it is turning again! Pulled the starter (and, despite all of the threads I read about the pain of removing the starter, I had no problems getting it out - nor re-installing all 3 bolts once the starter passed the bench-test). Now I am confused. Not the crank sensor (probably), not the alternator, starter or battery....next step is to cut off the spade connector on the solenoid and put on a new one. Also, I wanted to check the starter relay - and this is where the "help question" comes in - where the heck is it? I know what it looks like (from pictures at the autoparts store), but can't find it anywhere. If someone could let me know the location of this mysterious device, I would greatly appreciate it. Also any advise on where to go next (should the relay be good) would help. Would the Cam sensor keep the starter from running?
