Hi My tilt/telescopic wheel has always worked flawlessly. My M8 has been sitting for a bit as I source an ABS pump. now the tilt works fine but it doesn't move out. It seems like it went in too far as the signal switch is now tight against the dash. I found the following threads, I already tried pulling on it as I press the button for it to move outward, but it won't budge. When I use the switch to move it in, it can't go in any further but dash lights go dim, its seems to put a strain on the electrical system.
I also found this repair, though hoping I do not have to tear it all apart to get it back to the correct position:
Electric tilt stopped working
i had to pull it apart and replace those bearings in the plastic housing. Not fun at all. bah! it wasnt bad just a metal box with a telescoping shaft in it. i took mine completely apart and cleaned/lubed everything, only got a small glitch with the telescopic memory, also did this before...
www.lincolnvscadillac.com
tilt not working
i replaced both steering columns in my 97 and 98 marks they both had no telescopic function. now the replacements work on telescopic but no tilt function? any help would be great. thanks ken
How to Repair The Lincoln Mark VIII Tilt Steering Column
Submitted by: Eric1 Visit the Lincoln Mark VIII Forum for more help I am writing this for the 2nd Gen Lincoln Mark VIII (1997-1998), but the procedure should be similar for the Gen 1 (1993-1996) The tilt / telescoping steering column in the...
