ridindirrty
Hi guys, air-ride is sorted, on to the brakes and YES I have scoured every possible thread looking for answers already
. I have a symptom in my brake system that behaves like a weak accumulator but I don't think this is the issue. I've read posts referring to internal leaks and i'm wondering if this could be my problem. When the car is left for a few hours and then restarted, the ABS pump immediately turns on to build pressure in the system. We all know that this really ought not to be the case if everything is tight and holding pressure. Once charged though, it behaves pretty normally, the pump activating every 4th or 5th brake application which leads me to think that the accumulator is ok. It was replaced 6 or 7 months ago with a brand new unit.
Is there some sort of check valve that could be malfunctioning, letting pressure bleed out of the accumulator? Could air in a particular part of the system cause this behaviour?
The reason for the post is this: The car sat idle for 2 days and the pressure in the system was extrordinarily depleted. She seems to be taking longer to build up pressure after sitting for the last day or 2 leading me to believe that this sh*t is getting worse.
I've been preparing to do a system flush as i've noticed my pedal getting harder during stop and go driving in the extreme heat lately, making me think my brake fluid is boiling. Could this also have something to do with it?
