jthorn75
what do you guys reccomend for a system...3 10's or 3 12's or 2 15's.. i listen to rap mostly but i do listen to it all so that should be takin into condiseration
jthorn75 said:what do you guys reccomend for a system...3 10's or 3 12's or 2 15's.. i listen to rap mostly but i do listen to it all so that should be takin into condiseration
:Iwhatsupadrian said:Way to many factors need to be considered. SQ or SPL? Budget? Trunk Space? AMP? types of drivers???
itsnotmydaddys said::I
:I
i used to have 4 12s because i wanted the bass and had the space. i really depends what your looking for. right now im going to get just 1 ten and have it flush mounted in the spare slot, and put a heavy duty grill over it so i dont lose any trunk space, i have to figure out what im going to do with the batterie though.
itsnotmydaddys said:the only thing i was concerned with is how do you still lift up the cover when the speaker in it. if you mount the speaker on the cover it wont be able to lift it up. how would you do it. and what would you drop in it. and what amp
itsnotmydaddys said:well i have a 00 ls v8 with the audiophile system. im trying to keep the stock hu for now. i just bought 2 pair of boston rx87 and am going to put them in the doors. ive read some specs that say the audiophile system comes with 2 subs mounted on the back deck. not sure but i think they are 6x9(quik told me) also. so since im already going to have enough highs in the car im gonna need some bass. and for the other specs quik posted on the thread. what would you do im my case
whatsupadrian said:It will sound like :q:q:q:q but can be done... The RCA will share a common ground... which is not going to do very well for sheilding. Also the DSP will limit your volume on the amp because the crossover is built into your HU To get better output use a High to low converter and run your RCAs from that but if you insist on using the stock low level outputs then here ya go......
Heres how you would do your job...
yellow/red wire will be your remote wire to amp...
red wire is your hot wire which i don't recommend using for an aftermarket amp its just so small, run a new wire directly from your batter which is already in the trunk so it will be piece of cake. Make sure you keep that wire insolated so that it doesn't short on the stray grounded metal in your trunk.
white/red wire will be the core of the Left RCA, she sheild will be the black wire wrapped in what looks like tape, keep in mind that that will be shared with the right RCA.
grey/red wire will be the right core for your RCA, remember it will share the same sheild as your left wire.
Black wire (not the sheild) will obviously be the ground wire. again i recommend just running a new ground...
Here is also something to consider. Some amplifiers give off radical signal noise. Your antenna is right above your trunk in your rear windsheild. In my case my amps signal noise gives me poor reception. But then again i am running a 3000 watt class D amp.
