Asim said:
Motts / or anyone else for that fact...
Have you ran the same system with the stock and then gone to an aftermarket. Percent wise, what was the sound difference.
(I know there no mathematical answer).
I've got my complete system out of my last car but would like to keep the stock head it it will sound almost as good.
Asim
an aftermarket head unit will make a big difference, i think most will agree with me on this.. your not distorting your speakers by running the LOC off of them... you'll have an actualy set of RCAS, and you can control more wrather then just bass/trebble/fade/balance.. you can control your subs....
AUX inputs in the rear, 3 RCA pre-outs for front/rear/subwoofer, EQ support, all that stuff... there's a lot of MP3 capable decks now so that won't be an issue.
better CD specs can mean better sound quality. For example, the higher the CD signal-to-noise ratio, the cleaner the sound. And a CD receiver with a wider frequency response has more detailed sound. These specs are especially noticeable when using component amplifiers.
High power — with a very few exceptions, today's in-dash CD receivers all have built-in 4-way high power. When reviewing CD receivers, be sure to check the "RMS" wattage; it's a more accurate reflection of a built-in amp's real-world performance
Sensitive AM/FM tuner — aftermarket AM/FM tuners perform better than the ones in factory-supplied radios. Satellite radio controls — for state-of-the-art radio entertainment, look for satellite radio controls. This lets you connect the hardware to receive the digital broadcasts of XM Satellite Radio or Sirius Satellite Radio.
Tone shaping — all CD receivers have some form of tone-shaping, starting with simple bass and treble controls. And most CD receivers offer one or more of these features:
loudness for fuller sound at low volumes
bass boosts or bass enhancers for punchy bottom end
preset EQ curves for one-touch sound contouring
multi-band equalizers for precision fine-tuning
digital signal processing for reconstructing your vehicle's acoustic environments.
Security features — to help protect your investment, today's CD receivers offer many choices in theft deterrence:
detachable faces for take-it-with-you peace of mind
stealth-type faces that disguise the receiver to foil would-be thieves
"smartcards" that must be inserted for the receiver to work
programmable security codes
built-in alarms.
Preamp outputs — multiple sets of preamp outputs make it easier to install component amplifiers and subwoofers.
Many CD receivers have an auxiliary input (or the option to add one), so you can plug in even more sources of on-road entertainment:
a portable MP3, MiniDisc, or cassette player
a plug-and-play satellite radio tuner (some tuner/controller packages also have RCA audio outputs)
the audio outputs of a mobile DVD or videocassette player
the audio outputs of a TV tuner.
I'm sure someone will have something else to say.. :Bang
