Taillight keep blowing
itsnotmydaddys
Saint Louis
I had it in a month ago and told them to look at it. and they said it was fine just a bad bulb. so i changed it and got my car washed and it blew again. changed it again. then got it washed today and it blew again. i took the whole thing out and pluged the holes cause there was some water in it. and dunked it in a tub to c where the air was coming out. but no air bubbles. what am i missong. help me.
Welcome to the club!
Lemme guess. Right rear.
Buy a new one. :-(
-Matt
PS I did try sealing mine. No dice. Sucks, doesn't it?
yes passenger rear. how much was new one. what did your lm dealer say. im gonna silicon the hell outta it tom. and c if that helps.
My 02 has blown both rear bulbs even though they are supposed to be the long life bulbs.
I think I found it for $104.
Dealer? Hah. They said it was the trunk weatherstripping (which, did need replacing, but wasn't the cause of this)...I had 3" of water in the trunk when it rained for like a week straight. That is fixed thankfully. I should have my new coils / boots, and taillight on Monday. :-)
-Matt
Look at the black bezel that the bulb locks into and see if its warped at all. If it is warped then the 3 little light bezels will start to separated. Look very closely at the cluster (the 3 bezels) and look for a hair line seperation (crack) in the plastic. There will be one somewhere in that cluster. If you can't find it just silicone all the point that the 3 bezel connect to the rest of the black plastic (they should all be 90 degree angles).
