Lincoln LS 2001 v8 engine, throwing codes P1289 and P1299. Codes were read at Autozone.
Symptoms are:
1) Hard cranking long start and smell fuel when engine is first started.
2) The temperature gauge reads hot after first started. If the switch is cycled off then on again the temperature will go full cold and stay that way even after the engine has warmed up.
3) Just recently the engine overheated and had to be towed.
4) Cooling system was flushed recently and a new thermostat was installed in 2006.
The shop has recommended changing the CHT sensor. Does anyone have any other recommendations?
Symptoms are:
