Tony_1992
Hey guys. This week, after a long journey from Atlanta to Orlando, I started to find that the my LS 04 has a a loud noise coming from the front part of my car. It is louder when the speed is over 50 miles. And I can feel abnormal vibration on the throttle pedal.
At first I thought it was the engine problem and did worried a lot about it. But today I took it to a mechanist, and he told me that it probably from the worn out wheel bearing, though he can't tell which side is it. He pushed the engine speed to 3000 rpm and no such noise and vibration.
I searched the wheel bearing hub assembly on eBay. They are relatively cheap, 2 for under $100. I can imaging the process of replacing it. Remove the wheel, the brake pad and caliper. Then loosen the bolts that secure the hub. But in my experience, the hub assembly were usually extremely tight, as the metal parts contact is rusty.
I saw some videos on youtube about using a puller but most of them require turning a bolt against the axial which doesn't exist in this case since this is front wheel hub. The hub is solid in the center, no through hole. So in this case, what kind of tools should I use to get the hub out, if it's really rusty?
Thank you a lot!
Thank you a lot!
