milehighmikey
Well any I changed the fuel filter, and I'm pretty sure that the last filter was on the wrong way. The arrow on the filter was facing toward the outside of the car, away from the engine. The filter should be on the smaller line and the arrow should face the engine right? To help, the small fuel line should be the pressure side, and the larger fuel line should be the return right? If I'm wrong then I need to replace my filter again![]()
I found that loosening that harness from its restraint on the firewall gave me some wiggle room, but really, I used a screwdriver to override the locking tab on the connector, while pulling it with a set of long 90 degree bent tip needle nose pliers was the best way. Pushing inward a little bit after removing the detent (lock) of the connector also allows that latch to let go, but it is probably the hardest part of the job.
