Reading this post got me moving on doing this to my 05.
108,500 miles and from the looks of the fluid, OEM filter and gasket, I don’t believe the previous owner had this done.
After reading the great right up from AmpsterDutch, I made it a point to get it done today.
1 gallon of the Valvoline synthetic Merc VL was $18... grabbed me 4 of them from Wally World.
Now, I was really looking forward to draining the torque converter but the square/ trapezoid shaped rubber cover at the bellhousing didn’t get me where I wanted to be, it was in the general area of where that drain bolt should be but too far forward toward the engine, I was basically looking at the front of the flywheel...
Any how...
The drain pan was a bit of a SOB getting off as the rear tranny support was in the way, and after doing a little budging, damn near took a shower in the left over tranny fluid.
I looked for the filling bolt on the back/tail shaft end but didn’t see it.
So after the pan and filter all put back together, I did a flush procedure that I read in another write up by getting my wife to stop and start the car because I was dumping the old stuff from the tranny cooler line and then refilling a quart at a time.
All in all it went well.
No leaks, shifts real smooth and some peace of mind.
And while I had her up, been needing to put some refrigerant into her, she swallowed a can and boy is that air ice cold now.
I used a total of 15 quarts in case anyone is wondering.
Any how...
